You camera has a maximum aperature, and once it's open all the way, it's letting in as much light as possible. If you set your shutter to a higher speed, you're letting less light in (shorter time the shutter is open, less light hits the sensor). That is why your shots get darker with faster shutter speeds. You either need to add more light (shoot in brigher conditions or use a flash) or live with the slower speeds in order to properly expose your pictures. You usually don't need to shoot at 1/1000, btw.Originally Posted by DaShogun
Spike
