Quote Originally Posted by Sebastian
You're press, they should let you use flash. But if they don't, relax, auditoriums are not bad. And they're singing, so slow shutter speeds will work, unlike sports. You will be fine with the IS. My only concern would be white balance, as some auditoriums have terrible quality of light. My suggestion is leave it on auto white balance and do any cleanup in post. If they have 60hz lamps nothing you can do will guarantee the right colors anyways.
Thanks Sebastian....my hope is that since it is a newer school the lighting will be descent. And a thought just occured to see of the staff shooter has shot there and whether he will give me any settings he used...I doubt it though, he thinks I'm after his job.
JS
