Results 1 to 25 of 42
    Chicago Suburbs
    Re: My turn...HELP!!! Auditorium...low light
    You're press, they should let you use flash. But if they don't, relax, auditoriums are not bad. And they're singing, so slow shutter speeds will work, unlike sports. You will be fine with the IS. My only concern would be white balance, as some auditoriums have terrible quality of light. My suggestion is leave it on auto white balance and do any cleanup in post. If they have 60hz lamps nothing you can do will guarantee the right colors anyways.
    -Seb
    My website
    Moderator
    Mar 2004
    McCordsville, IN
    Quote Originally Posted by Sebastian
    Thanks Sebastian....my hope is that since it is a newer school the lighting will be descent. And a thought just occured to see of the staff shooter has shot there and whether he will give me any settings he used...I doubt it though, he thinks I'm after his job.
    JS
    Chicago Suburbs
    You should be fine especially since it's a newer school. Don't bother getting his settings, just go and treat it like any other situation. I have comfortably shot inside dim auditoriums with 1/50 and up speeds at ISO 400 and up. The IS helps you stay steady, but won't stop any subject blur.
    -Seb
    My website
