It looks as if you used flash, which is a blueish light, like daylight.
When you do that, the camera automatically uses the flash white balance.
The camera probably is not going to get this right - you need to start making changes manually.
One way to solve this is to use a CTO colour filter gel over the flash.
That makes the flash light more orange, closer to the tungsten light.
If you shoot in RAW mode (not JPEG) then you can fix the colour afterwards, once it's all balanced to the same (orange) light you can adjust it in the editor of your choice like Photoshop, or Lightroom, or Paint Shop Pro.
But you will still get that mix of blurring and sharp images because the camera is trying to balance the flash light with the background light, and to do that it needs a long exposure (slow shutter time) to get the background.
You can speed up the shutter if you turn up the ISO speed, but the image will get more grainy.
The higher the ISO setting, the shorter the shutter speed can be and the less blurred the dancers will be.
But you'll still need that CTO gel on the flash for colour balance.
