Digital Camera Pro Reviews >>
Results 1 to 2 of 2
    Jun 2010
    HP PB360t Digital Camera - Charger won't charge battery
    I just bought an HP PB360t camera. I had no trouble charging the battery in the charger the first time. Now, I can't seem to get it to charge. The charger is universal so the battery doesn't quite fit right.
    Can someone tell me which way to put the battery in the charger? I read the manual and it doesn't help. The diagram isn't clear.
    I also read that when you hook it up to computer with USB that the camera automatically charges. Is that true?
    Thanks.
    Aug 2001
    Re: HP PB360t Digital Camera - Charger won't charge battery
    Did a charger come with the camera or does the battery charge in the camera? Maybe it's the battery and not the new charger. However, I am generally suspicious of off-brand batteries and chargers. I have had very bad luck with off-brand batteries. So my guess is it's the charger - especially if the battery doesn't fit right.
    Charging with the camera's USB cable will only work if the camera's USB connection is set up for that. I don't think they usually are. So I wouldn't expect that to work.
