Digital Camera Pro Reviews >>
Results 1 to 3 of 3
    May 2006
    UK
    HELP! SanDisk SD Ultra II Plus stuck in Ixus 800 IS (SD700)
    Hi and Help!
    I recently purchased a Canon Digital Ixus 800 IS (that's a UK name, I think, might be the SD700 in the US) and a SanDisk SD Ultra II Plus Card 1 GB. All well and good, except the SD card is stuck in the camera. It went in allright and stores photos fine, but I can't get it out of there. It will pop in and out a little when pressed, but even when it's popped out a bit, I can't shift it. Can anyone help me?
    Cheers,
    Charlie.
    Aug 2001
    Re: HELP! SanDisk SD Ultra II Plus stuck in Ixus 800 IS (SD700)
    I seem to remember it being a little hard to get SD cards out of the little Canon digitals. There should be a little ridge on one side of the card. If you can get a fingernail in there, you should be able to pull it out. That's what it's there for. Hopefully it's just a tight fit and the card isn't really jammed or anything like that.
    May 2006
    UK
    Thanks, it was a small piece of plastic protruding from the card, I've filed it off and now it's fine.
