Nikon Camera Equipment Forum
Discuss Nikon digital cameras, Nikon film cameras, Nikkor lenses, Nikon camera accessories, etc. - Your Nikon cameras forum moderator is Franglais.
Nikon Review Index >>
Nikon Digital SLR Reviews >>
Nikon Nikkor Zoom Lens Reviews >>
Nikon Nikkor Prime Lens Reviews >>
Nikon Camera News, Pro Reviews & Articles >>
Results 1 to 8 of 8
    Member SenorNikonMan's Avatar
    Aug 2007
    Texas
    Sync Speed vs Flash Shutter Speed
    I'm confused. From what I read, my D200 has a flash sync speed of up to 1/250 sec. but it's flash shutter speed only goes up to 1/60 sec. Can somebody please explain what the difference between sync speed and flash shutter speed is. Thanks!
    Aug 2001
    Re: Sync Speed vs Flash Shutter Speed
    I'm confused, too. I've never heard of "flash shutter speed." I would assume it's just another name for flash sync, if the numbers weren't different. And 1/60th of a second for flash sync - especially on a camera like the D200 - would be unacceptable.
    Aug 2007
    Texas
    Here is where I got this information from:
    http://www.dcresource.com/reviews/nikon/d200-review/
    Scroll down to the Bracketing/Flash section. That's where it says that the D200 sync speed is (1/60 - 1/250) while it's flash shutter speed is (1/60 - 30 sec.)
    Just this weekend I wanted to set my camera's sync speed faster than 1/60 but when I went into the Flash Shutter Speed menu it showed the fastest as 1/60. Was I in the wrong menu?
    Senior Member WsW-WYATT-EARP's Avatar
    Jun 2006
    UNION GROVE, WI
    I noticed the same thing with my D300 - From what it seems - In aperture mode - it sets the shutter speed to 1/60 with the onboard flash or external flash attached. If you want a faster shutter speed then go to shutter priority and it will max out at 1/250. The menus are seperate for the 2 as Senior Nikon Man said
    Ben
    Bodies: Nikon D300 - Nikon D50
    Lenses: Nikkor 50mm f1.8 D - Tamron 17mm - 50mm F2.8 - Nikon 70mm - 200mm F2.8 VR - Nikon 1.7 Teleconverter
    Lighting: Nikon SB600 speedlight - AlienBees (2) B400's - Polaris Flash Meter
    Stabalization: Manfrotto 190XPROB tripod - Manfrotto 3265 joystick head
    Aug 2007
    Texas
    Quote Originally Posted by WsW-WYATT-EARP
    That's good to know. Thanks for clearing that up for me. I'll try that next time I want a faster sync speed.
    All these advanced features on the new digital SLRs are great but I've had my D200 a year now and I still don't know how to program it to do most of these things.
    BTW, it's Senor and not Senior NikonMan.
    Jun 2006
    UNION GROVE, WI
    Quote Originally Posted by SenorNikonMan
    Tomato - Tamato
    Ben
    Check out our D300 Pro Review! deckcadet's Avatar
    Oct 2004
    Gainesville, Florida, USA
    One more thing... if you're shooting in Aperture Priority mode, the flash shutter speed is simply the *slowest* shutter speed it will go for. If it would cause overexposure, it will still raise the shutter speed up to the sync speed (and higher if you turn on Auto FP sync with a compatible flash unit). I generally lower mine to 1/40 or 1/50s as that lets in a bit more ambient light in some of my typical shooting situations.
    You might also want to experiment some with using Manual mode with flash, perhaps even in combination with Auto ISO with the max ISO set to 400 or 800.
    Harrison
    Nikon Forum / Digital SLR Forum Moderator | moderator bio
    Check out our new Nikon D300 Pro Review D3 review coming soon...
    Nikon Samurai #9 | NPS Member
    10 Lenses • 5 Bodies • 3 Macs • 1 Sore Back
    The Polariser fx101's Avatar
    Aug 2007
    New York
    Quote Originally Posted by deckcadet
    Deckadet is right on. You only get to set the minimum flash shutter speed in apperture priority mode. The camera's smart enough to pick the right speed for the job. Only in shutter priority can you feed the camera an exact flash sync speed.
    --The camera's role is not to interfere with the photographer's work--
    --Cibachrome: It's like printing on gold.
    --Edit my photos as part of your commentary if you want to.--
