Results 1 to 9 of 9
    Jan 2009
    Need Quick Help - Light Painting Help
    OK, so I'm trying light paint photography. I have an Olympus FE-340, 8.0 megapixel and 5x zoom. So, when I use light painting photography, I have some options; P, a shaking hand, Auto, or scene. Now, the shutter speed. I have 0.0, +0.3, +0.7, +1.0, +1.3, +1.7, +2.0. I use +2.0. But I want to be able to take longer shots to be able to draw cool things in the air with it. Thing is, I don't know what do do. Any help?
    Mar 2004
    UK
    Re: Need Quick Help - Light Painting Help
    Those aren't shutter speeds, those are compensations giving just a little more exposure.
    It's a start, and +2.0 is the best you can get.
    What you need is "B" mode - to use as long an exposure as you want.
    Or "M" mode to manually set the shutter to 15 or 30 seconds.
    Unfortunately your camera doesn't do either.
    The best you can do is to use night scene mode, that uses the slowest possible shutter speed. But at only 4 seconds I doubt if you can light paint with this camera.
    I used the online manual, check this is the same as for your camera.
    http://resources.olympus-europa.com/...nual%20_EN.pdf
    PAul
    Jan 2009
    I have one other camera - it has M, I believe.
    Jan 2009
    I apologize for the double post. It worked! I used "2 and it got good, I can draw quick doodles like lasers.
    Mar 2004
    UK
    You have to draw really quick !
    PAul
    Jan 2009
    Yeah, but sometimes it goes off screen and then I can not draw well. Also, I don't get much time from that, unlike those who can get 15 seconds.
    I have different options. M, A, S, P, and Auto. Which one allows the most shutter time? This camera is a FujiFilm E510.
    Mar 2004
    UK
    I expect M on the Fuji will give you most shutter time, but I recommend you read your manual to be sure.
    Unfortunately I can't just download a manual for that camera. Fuji UK charge £9 to send out a copy
    PAul
    GB1
    GB1 is offline
    Moderator GB1's Avatar
    San Diego CA
    The M setting is the way to go. Set it for the longest shutter speed time possibe, and make sure that the area isn't too backlit.
    G
    My Site
    Nov 2004
    Basingstoke UK
    One other thing - I assume you're using a tripod to make sure that the camera is solid.
    Roger R.
    My Web Site: www.readingr.com
    DSLR
    Digital
