Need Help Using Ilford Delta 3200
I finally got my new camera and lens and want to shoot some b&w film. Having never used Delta 3200 (aka - Charles Hess) I wanted to know the characteristics of the film.
What speed do you shoot it at? What directions do you give to the lab?
The problem with my camera is that it only goes up to ASA 1600. I am imagining that I could always do -1 stop exposure compensation to adjust the film speed, but is this necessary? Somewhere, I thought that you typically shoot this film at 1600, and process normally.
Any advice would be helpful.
Thank you,
Loren
Half of one, six a dozen of the other...
Thank you,
Loren
Loren,
With many bw films, this being one of them, being able to shoot at the highest ISO is simply a metering aspect. IOW, when a certain aperture or shutter speed is important, and you want the meter reading to fall within a range that can be set on the camera.
The one stop difference between 3200 and 1600 with a film as good as this is going to be very small. In fact, I'd be surprised if the negative density difference between the two would be that noticable. Both would certainly be equally printable...
Anyway, as you point out, it's pretty common to pull this film one stop anyway. So, whatever you decide to do; whether meter at 1600 then compensate by shooting one stop under, or meter and shoot at 1600 and have your lab pull process it one stop, I doubt you'll be disappointed with the results...
