Help, please! Yesterday, the kit telephoto lens (75-200) from my new Sony Alpha-100 fell into the ocean while I was photographing some boats. It sat in salt water for about 12 hours before the tide went out and I could find it. I immediately put it into isopropyl alcohol, hoping the alcohol would extract the water (it's a trick I use in woodturning to dry out wet wood).
I removed the UV filter from the front, and tried moving the mechanisms. A narrow, black felt band that was behind the focusing ring fell out -- it had been held in place with glue, which failed.
The lens is full of water/alcohol. What do I do next? I am relatively comfortable with optical systems (I used a microscope in my day job as a pathologist), but I'm not sure how hard it is to dismantle and repair a lens.
Thanks so much for your advice.
Charles in Victoria, B.C. (who is hoping hye doesn't have to buy a new telephoto lens)
'Slim' - K10D and *ist DL w/ SMCP DA 70mm 2.4 Limited, SMCP-DA 18-55mm f/3.5-5.6, SMC M 28mm f/2.8, SMC M 50mm f/1.7, and Tamron AF75-300mm f/4-5.6 LD Macro
Slim of the Clan O'Canon - A1 w/ FD 28, 50, 70-210 & Sigma 500/1000 f8/f16
