Digital Camera Pro Reviews >>
Results 1 to 2 of 2
    Senior Member
    Apr 2020
    What’s the Difference Between the Deep Web and the Dark Web?
    You might have heard the terms dark web and deep web used interchangeably in the past. While the two have similarities, there is a slight difference between the dark web and the deep web. And we are here to clear the confusion for you once and for all.
    The deep web vs the dark web would not be a fair comparison because the dark web falls the under the umbrella of the deep web. And while one is not completely different from the other, there are similarities between the two. Allow us to help you understand what the dark vs deep web is in thorough detail. And to properly understand the difference between the dark web vs deep web, you will first need to understand what each term means.
    The deep web is that part of the web protected by an additional layer of security. You might say that the standard web is the ocean’s surface, and the deep web is the water beneath it. And you have only touched the ocean’s surface if you have visited the common web.
    The dark web, in contrast, is a sub-category of the deep web mostly used for shady and illegal activities. And if you are not careful when accessing the dark web, you could end up in serious trouble. The dark web is that section of the deep web that requires specific dark web search engines, browsers, and tools to access it. And it might even be safe to assume that the portion of the dark is even smaller as compared to the standard web that we use every day.
    Member
    Nov 2019
    Re: What’s the Difference Between the Deep Web and the Dark Web?
    While there are no major search engines like Google on the dark web, it is still possible to navigate the dark web landscape through search engines and directories if you know where to look. The nemesis market site can help you. There you will find all verified and working dark web websites.
