Rack battery system with expandable capacity from 2.4kWh to 96kWh. Looking for an energy storage solution for your commercial needs? Consider our Rack System series, featuring a lithium battery with expandable capacity ranging from 2.4kWh to 96kWh. With a safe BMS system, long life cycles, and high performance, this series can keep your business powered on all the time. Need even more energy? Each single unit can be customized to provide a maximum capacity of 56.3kWh. Plus, we can tailor our solution to meet your specific requirements.
Rack batteries are a type of LiFePO4 solar battery designed for use in applications where space is limited or where multiple batteries need to be connected in a single system. These batteries are specifically designed to fit into standard rack enclosures, making them easy to install and integrate into existing systems.
