The BPlus series of smart pure sine wave power inverters presents our vision for the future of power inverters and brings six new products with full of advanced technology. BPlus-300W, BPlus-600W, BPlus-1000W, BPlus-2000W, BPlus-3000W, BPlus-5000W all best power inverter for car/truck(RV/vehicle inverter).
BPlus-300W support 12VDC |120VAC/230VAC
BPlus-600W Support 12VDC/24VDC | 120VAC/230VAC
BPlus-1000W Support 12VDC/24VDC/48VDC | 120VAC/230VAC
BPlus-2000W support 12VDC/24VDC/48VDC | 120VAC/230VAC
BPlus-3000W support 24VDC/48VDC | 120VAC/230VAC
BPlus-5000W support 48VDC | 120VAC/230VAC
These six new pure sine wave inverter our pursuit of the ultimate. The plus series pure sine wave power inverter breaks through the peak parameters of high-frequency power inverters, from traditional 2x peak to 3x peak. It lasts up to 2Min at a 200% load. The full range of BPlus series pure sine wave power inverter supports the purchase of displays, up to 30 meters of remote control. This is not simply a display screen, but also in the display DC/AC at the same time, the voltage supports the display of battery power, output power, frequency, temperature, and it also can set commonly used parameters, electricity pool type (support for lithium battery, AGM, custom), The BPlus series pure sine wave power inverter is more suitable for high-temperature areas, with over-temperature protection rising from 75 degrees to 90 degrees. Smart control fans are no longer single.
As the temperature rises and starts, when the temperature reaches 50 degrees or the load exceeds 75%, the fan will automatically start to cool down in advance, good dispersion The BPlus series pure sine wave power inverter has been upgraded with USB output upgraded from 5V500MA to 5V2.1A, With bipolar output, the output's power quality is greatly improved to accommodate any load. Because we designed from the beginning.
The most critical thing is that we will provide the warranty for 2 years, so you can use it with peace of mind.
This is our ultimate pursuit of the future, the BPlus series of smart pure sine wave power inverters, a power inverter for you. You deserve it!
