• 09-24-2006, 10:54 AM
    texaskiwi
    Picture problems w/ Powershot A85, Help please!
    First off, I've owned the camera for 2 years but have barely used it. It's never been dropped or damaged in any way.
    I took this camera to work the other day to take company photos. I noticed a fuzzy white vertical line develop on the viewing screen after the camera had been on a couple minutes. When I turned it off, it went away. But as the camera was on it began to develop the same thing, starting with a fuzzy area at the top that moved down. When I put my hand over the lens to block out all light, this white area remains visible. This will go away completely once I turn the camera off but it will start all over again the next time. This white area DOES show up on images (otherwise I wouldn't care). If I switch the camera to the playback position (ie so I can view pictures I've already taken), I can see images that I took when I first turned it on which don't have this problem just fine. So this is not a screen issue. It has also had some flickering on the screen, similar to image you might get on a tv if you bump the antenna. This only happens right after I turn it on.
    Here are some sample photos showing the progression of the white, about 60 seconds after I turn it on. Nevermind the fact that the picture quality (the grainy lines) is horrible compared to what it used to be.
    http://img.photobucket.com/albums/v4...i/IMG_0774.jpg
    http://img.photobucket.com/albums/v4...i/IMG_0776.jpg
    Anybody know what would cause this and if there's anything that can be done short of sending it to Canon?
    :mad2: :mad2:
  • 09-26-2006, 12:48 PM
    texaskiwi
    Re: Picture problems w/ Powershot A85, Help please!
    Nobody has any ideas?
