• 03-11-2007, 08:22 AM
    EmyleeShadow04
    please PLEASE help!! I dropped my camera in water!!!
    I dropped my VERY expensive digital camera in water. I took out the battery and tried to dry it out with my blowdryer. The screen is fogged up around the edges, will that go away? It will take pictures but not very well.
    I'm so worried. Once it dried out more will it be okay? This camera w as a gift and it means a lot to me. Not to mention that i love photography.
    Someone please tell me my camera is going to be OK. :(
  • 03-11-2007, 08:26 AM
    EmyleeShadow04
    Re: please PLEASE help!! I dropped my camera in water!!!
    http://www.crutchfield.com/S-wyHdRWk...p?i=158DSCW100
    that's the camera i have.
    I am so upset and so worried. I don't have much at all, my camera means so much to me. :(
  • 03-11-2007, 09:24 AM
    Greg McCary
    I washed my cell phone in the washer twice, It took a couple of days to dry out but it worked. But that jump in the swimming pool ended it's life.
    Greg
  • 03-11-2007, 10:58 AM
    starriderrick
    Here is what I recommend;Depending on how old it is.If it's less than 30 days old...Let it dry out, call the manufacturer, tell them it stopped working. If they find NO water in it.Chances are good you'll get a replacement.If they find water....Well.You know.
    Sorry about your mishap.I can relate.
    Rick
  • 03-11-2007, 01:01 PM
    mwfanelli
    Well, let me tell ya... Years ago I dropped by S100 Elph into the Brandywine River. Not once, but three times. When I got it home, I dried everything off. The CF card worked fine when dried (I still have and use it). The battery was fine. The camera was toast. It cost more to fix than it was worth so I bought a new camera. Most cameras hate the water. If this is something that might happen again, get a "hazard warranty" that will replace it. Otherwise, chalk it up to bad luck. Sorry...
  • 03-11-2007, 02:55 PM
    gryphonslair99
    Rick
    Spoken like a true thief in the making.
  • 03-11-2007, 05:23 PM
    pisco
    best thing you can do is let it dry. Don't use it for a few days, remove battery, memory, etc. Don't try to use it now.
    I have a canon powershot that was floating in salty water, It gave me an error code at the begining, but after 2 days drying it was fine (2 years ago, still works).
    Another friend left his camera on the rain all night, he left it drying a couple of days and no problem.
  • 03-11-2007, 07:13 PM
    PhotoGirl
    I don't have any advice, other than what has already been stated (starriderrick's idea made me smile!:D ). I feel for you, EmyleeShadow04, and I know what you mean about your camera meaning a lot to you. I hope it works after it dries out.
  • 03-12-2007, 06:03 AM
    Stupendous Man
    Depending on how much water is in it, and for how long, you may need to let it dry for SEVERAL DAYS. remove the battery & everything else. Do not turn it on until it is thouroughly dried or you could fry it permenantly. The lenses fogged up will dry over time. It may speed things up to store it in a room with a dehumidifier running.
  • 03-12-2007, 07:33 AM
    freygr
    As long as water did not get into the lens and you did remove the battery. If it completely drys out before you install the battery most likely all is well. What kills the electronics is the water can supply a current path for the battery to discharge through frying the electronics in the current path.
    Now it the camera was just in and out it's not much of a chance of major damage, but if it was in the water for a long time it's most likely a paper weight.
  • 03-12-2007, 10:42 AM
    mwfanelli
    Actually, the polluted water in my camera made a mess of the sensor. If it isn't water sealed, it will probably be more than just the electronics.
  • 03-12-2007, 01:51 PM
    Canuck935
    Also, sounds like you dropped it in freshwater? If so just take everyone's advice and let it dry out real good before using it again. If it was saltwater... time to buy a new camera.
  • 03-13-2007, 06:28 AM
    another view
    Good point, salt water eats just about everything. If it was fresh water, the only thing you can really do is leave it alone with the battery out of it. Leave the battery and memory card doors open to try to promote air circulation. Personally I'd give it a couple weeks because you only have one chance with this. No guarantees this will work, but good luck with it.
  • 03-30-2007, 09:49 PM
    hughosborn
    Yeah I got pushed in a pool once by a short dwarf-like english girl with absolutely no neck who we called chafey due to her chafed-like walk. We didn't know her. Anyway, I was pushed in with my new mobile and my dad's new camera in my pocket and the boardgame pictionary in my hands. Pictionary floated so it came out mostly unharmed. The mobile and camera didn't work. I left them to dry but being extremely drunk at the time I probably tried to turn them on at least once. Anyway they didn't work after they were dried so I decided it could be the salt pool water. When I got home I took my phone apart and let it soak in warm salty water thinking that perhaps this will dissolve the salt particles and move them out of the phone. The phone ended up working pretty much 100% eventually but the camera never made it cause you can't really take that apart. And Chafey, well, we'll never know what became of her. I just hope I never see her again.
    I hope you only dropped it in freshwater and you get lucky (not with Chafey).
  • 04-02-2007, 12:11 AM
    Derekz93
    DONT MESS WITH IT. Let it dry out completely. If you turn it on you may risk damaging it MORE!
  • 10-25-2010, 04:43 PM
    Cheetah53
    I have had two experiences - both with the same brand and model. I dropped my Canon 5D MkII in a fresh water stream and after turning it on and off several times over two days I then sent it to Canon. It could not be repaired! As fate would have it I dropped my new Canon 5D MKII in another fresh water stream and based on what I was told to do after my first experience I left it turned off for one week. I then reinserted the battery memory card and put a lens on it and guess what? It worked just fine! It seems the key here is to not turn it on when it may have water inside as you may fry the circuitry.
    Good luck man! I know how you feel...
  • 10-25-2010, 05:38 PM
    n8
    Try some rice. Honestly! I did this with my last cell phone for about 24 hours and it really helped. I wish I'd known not to turn things on a couple years a go when I jumped in a pool with my camera in my pocket.
  • 01-11-2013, 01:47 AM
    yad99in
    Remove the batteries completely make it dry for 2-3 days, might be it could help you. but dont try to turn it on as power will flow and chip can be destroyed.
  • 01-13-2013, 07:38 AM
    gryphonslair99
    I think it is a little late since this thread is 5+ years old.:wink:
  • 01-14-2013, 04:27 PM
    jamesbarns
    Haha just a little late. But you never know
