Battery Drain
Printable View
  • 07-26-2004, 07:38 AM
    KRPM
    Battery Drain
    Hi all,
    I'm having a real problem with battery drain at the moment and it was never a problem before. I have a 35mm SLR that was in storage for a while. I made the cardinal error of not taking out the batteries and you guessed it...they leaked. I cleaned the contacts up as best I could but the camers now eats batteries, even when its turned off. What is going on here and is there anything I can do?
    Thanks
  • 07-27-2004, 09:02 AM
    paulnj
    KEEP CLEANING IT!
    CLEAN, CLEAN CLEAN!!
    IF that DOESN'T work.......{ I FEEL} it may need a repair.
  • 08-07-2004, 03:18 PM
    GB1
    You may be entitled to a FREE repair
    What type of batteries are they? I believe the major brands have guarentees that their batteries will not leak or they will repair the device free of charge.
    Check it out!
    GB
  • 08-18-2004, 07:32 PM
    mikishots
    Leaky batteries
    There is a short in your camera that is causing high leakage currents. This is often a result of acid flowing onto the PCB contacts.<p>The cell manufacturers will not guarantee alkaline batteries from leaking because the cathode is the outer casing - if you leave a cell connected, the cathode will dissolve (it has to, that's how alkaline cells work).<p>You can try cleaning it yourself, but I think a shop would be easier and safer.
