• 02-07-2022, 07:28 AM
    donaldrsimonn
    USB Flash Drive Duplicator Buyers Guide – 2022
    Nexcopy releases their 2022 buyer's guide for USB flash drive duplication equipment. This buyers guide lists valuable information to consider before making an equipment purchase.
    This buyers guide lists the top ten questions to consider before making an equipment purchase which can range from a few hundred dollars to over several thousand dollars. The document is designed to answer important questions about the work flow, demands and expectations a company will have with regard to USB flash drive duplication, distribution and fulfillment.
    Greg Morris, President of Nexcopy Inc comments, "With the wide spread integration of USB 3.0 technology into the computer market place, now is a time to revisit the advantages of computer based duplication equipment compared to standalone USB duplication equipment." Morris continues, "From yeas past, the standalone systems provided important speed advantages over PC based duplication equipment; however, in todays market this no longer rings true. It is important the consumer understand the differences between PC based and standalone equipment and how those features and benefits will be suite their needs."
    The optical drive is disappearing in laptops and computers and as a result, the USB flash drive, or thumb drive, is the ideal tool for sharing data in the year 2022. The USB flash drive is a small, easily transportable device which holds vast amount of data storage capacity. Flash drives are universal devices used in Windows computers, Apple computers, Linux computers, Smart TVs, car stereos and any other device which has a USB port. The universal acceptance of the USB flash drive in conjunction with the optical drive disappearing explains their continued popularity.
    Considering the lack of optical drives found in new computers the USB is replacing the CD-R for duplication needs. In fact, some companies require the use of many flash drives but with different information on each thumb drive, also known as data publishing. There are duplicators for each type of situation and this USB flash drive duplicator guide will help determine which type of USB copier is best for your needs.
    Coping USB sticks manually one at a time will is a time consuming and expensive process. Using a USB flash drive duplicator (also called a USB copier) increases efficiency and decreases costs.
    For the complete USB flash drive duplicator buyers guide please visit our website listing additional features and include the top 10 questions to ask yourself before making an equipment purchase.
