Larger LCD cameras, HELP!
Hi, I was thinking of buying a digital camera (ultracompact such as Canon SD450 or Panasonic DMC-FX9) and I know both of them have 2.5" LCD screens
I've heard that they crack easily, can anyone confirm this? Or are these false rumors? Also, if you have experienced cracked screens, how do you go about fixing this? Will warranty cover or what?
thank you for the info.
Re: Larger LCD cameras, HELP!
Cracking of the LCD screen is rare and almost always due to user abuse. The warranty may or may not be in effect depending upon what the company believes happened. My only suggestion is to use a clear protector over the LCD if no protection is provided. This will prevent scratches.
As a sports shooter I abuse my gear, never broke an LCD on the camera but I do need a new laptop screen for my Toshiba. As for the camera I just keep breaking lenses off at basketball games (three 28-135mm lenses in three years, last one was a rental :eek: )
JS
If you are planning to buy a digital camera …………..then I would recommend you to buy ………… Canon SD450…….hope you have not made your decision yet!!!…..I have some good reviews……
http://www.inods.com/iNods/search.jsp?query=Canon+SD450
Just check may be they can help you make a decision……………
And as far as cracking of LCD is concerned I think it is pretty rare…………a protector can certainly be helpful…..
ms12d,
I have the FX8 camera and it is wonderful, but as you point out, there are issues with the LCD's on these cameras, as I have found out to my cost. Most of the screens are fine, but some are failing without being dropped or mistreated.
People with genuine faults (not damage) are by and large being fobbed off and are not following through due to the lack of publicity. Responses like most on this thread are quite common, as the issue is not generally being acknowledged.
As I say, the camera is GREAT and a joy to use - just be aware that if you do have a genuinely failed LCD, this is now becoming a well known issue. If you bang it or drop it, then hey, chalk it up to experience and get a newbie - a common home insurance claim, I believe...!
Still, this screen failure IS being investigated by Panasonic (I just sent them a 36 page evidence document containing my findings from the links below) and if you need any more info then please check out the following links - stories and photos which are too similar for mere coincidence...
FX8 Screen Broken from photo.net (or "fx8 LCD" as a Google search)
Link: http://www.photo.net/bboard/q-and-a-...g=200601120801
Cracked Screen Issue from digitalcamera-hq.com
Link: http://www.digitalcamera-hq.com/pana...7-reviews.html
Cracked Screen Issue from forums.dpreview.com.com
Link: http://forums.dpreview.com/forums/re...ssage=16500018
FX7 Review from epinions.com
Link: http://www.epinions.com/content_180949651076
Panasonic LZ2K Screen Issues
Link: http://reviews.cnet.com/Panasonic_Lu...6&cval=1491996
Canon SD300 Thread – Identical issues to the Lumix/Panasonic screen fault
http://66.102.9.104/search?q=cache:B...00+cracked+lcd
FX8 Screen Cracked! From clubsnap.com forum
Link: http://www.forum.clubsnap.com/showthread.php?t=173388
Hope this helps - I love the FX8/9, but just so you are aware from the get-go!
warrent1971
Just to clarify, I'm not talking about external cracks or damage to the plastic LCD cover, which is very robust, but the inner LCD itself, which bursts, not due to impact, but either from the proximity of the LCD to the Menu buttons, or expansion and contraction of the LCD in cold and warm conditions, or a combination of both.
The Canon SD300 seems to be a victim of the same problem, too, as one of my links details.
Happy snapping - gotta luv that Lumix!!!
