Digital Camera Pro Reviews >>
Results 1 to 5 of 5
    Member
    Apr 2020
    How to Decide Between Water Heater Repair
    Based on the manufacturer's suggested service life, the life expectancy of a water heater is about eight to 12 years. That varies with the location and design of the unit, quality of installation, maintenance schedule and water quality. If your water heater is more than 10 years old, leaks around the base of the tank or if it works erratically, it's probably time for a replacement. You may also choose to upgrade to a more efficient model to cut your energy expenses.
    In some cases, repairs and troubleshooting can save your existing water heater. Before you look for a replacement, make sure that an electrical problem, such as a blown fuse or tripped breaker, isn't the reason for the unit's failure. Regular water heater maintenance will extend the life of your unit, and some repairs — such as replacing a pressure relief valve or heating element — are pretty simple.
    Member
    May 2020
    Re: How to Decide Between Water Heater Repair
    Quote Originally Posted by carnachpace View Post
    Before making repairs or purchasing a new water heater, check the nameplate on the side of your current unit. Here you'll find helpful information, including the tank capacity, insulation R-value, installation guidelines, working pressure, model and serial number. If you have an electric water heater, the nameplate will also list the wattage capacity and voltage of the heating elements.
    Senior Member
    Apr 2020
    Whatever your hot water needs may be, Bonney has the solution. We repair, service, and install all brands of residential and commercial hot water heaters in Sacramento. We also sell a complete line of gas hot water heaters and electric hot water heaters from Bradford White, State, Rheem and A.O Smith. We also service, repair and install boilers.
    Interested in a tankless water heater in Sacramento? Bonney Plumbing installs, services and repairs tankless water heaters too! Call today for a free estimate for a water heater replacement in your home.
    Don’t forget to ask us about installation of energy efficient hot water heaters that qualify for utility company rebates.
    Member
    Apr 2020
    Slcwaterheaterrepair specializes in water heaters in Utah, and we can come out the same day you call! Our water heater services are 100% guaranteed. Whatever your needs are for your water heater — whether it needs to be replaced, repaired, or installed — we can help! We are available 24/7 and work to meet your water heater needs. Whether it is for your commercial or residential property, our Utah plumbers will provide you with service at the expert level while working to stay within your budget. Contact us to schedule a FREE consultation. Here is the website
    Senior Member
    Nov 2019
    U heeft een reparatiebedrijf nodig met ruime ervaring. Bezoek de CBS Renovatie website https://cbsrenovation.nl/. Ze zijn volledig bezig met reparatie- en constructiewerkzaamheden. Voor de installatie van sanitair hebben specialisten alle benodigde gereedschappen en kennen ze alle nuances van het werk. Naast loodgieterswerk verzorgt het bedrijf interieurbouw, alle soorten demontagewerk, timmerwerk en uitbreiding van woonruimte. De specialisten van het bedrijf zijn gekwalificeerd.
