As your trusted LiFePO4 lithium battery manufacturer, supercharge your robots with our lightweight & high energy density batteries! MANLY LiFePO4 lithium battery is 1/3 lighter weight than a traditional battery with unleash unstoppable power and extend operation times for your robot! As an expert battery manufacturer, we offer a long lifespan and low self-discharge batteries for powering your medical equipment. MANLY LiFePO4 battery boasts a lifespan of more than 5000 cycles. With a low 2.5% self-discharge rate per month (at 77℉/25℃).
MANLY batteries work great, even in rough conditions. If you drop or hit these batteries hard, they don’t catch fire or explode. They are safe. MANLY LiFePO4 batteries work in cold and hot. They can handle temperatures from -20°C to 75°C (-4°F to 167°F). They keep working, always. Elevate home energy storage with safe and efficient batteries from your trusted battery supplier. Store solar and wind power confidently, with extended lifespan and cost-effectiveness. Power your home sustainably and save! Maximize solar energy with MANLY efficient and stable batteries! MANLY LiFePO4 battery typical energy efficiency is 95%. The final 20% charge is particularly inefficient with efficiencies of 95%. Unleash your solar potential with confidence!
The 12v 9ah battery is a reliable and versatile power solution for a wide range of applications, including RVs, medical equipment, drones, and emergency backup systems. Its LiFePO4 chemistry ensures a much longer lifespan compared to traditional lead-acid batteries, along with enhanced safety and higher efficiency. This battery is designed for deep cycling and high performance, making it ideal for situations where space, weight, and reliability are crucial. It is perfect for replacing traditional lead-acid batteries, offering better performance in a more compact and lightweight package.
MANLY Battery offers custom options to ensure that the 12v 9ah battery your unique specifications. Whether you need a specific capacity or terminal configuration, we deliver products that match your requirements. Its compatibility with conventional solar photovoltaic controllers makes it a flexible upgrade for solar and off-grid systems. The battery’s integrated Battery Management System (BMS) offers multiple layers of protection to ensure safe and efficient operation. When used in parallel configurations, the maximum charge and discharge currents are calculated by adding up the values of each battery and then reducing it by 25%. For instance, two parallel 100Ah batteries would deliver a combined current of 200A minus 25% (50A), resulting in a safe maximum output of 150A. This design prevents any imbalance from triggering the BMS, ensuring stable performance even under heavy loads.
